madmercedes
Hi All
Would some one know what is wrong with my lorry? One of the first 'fly by wire' engines. It has a slight miss that all the fitters insist its fuelstarvation.
Revs fine when ticking over. Under load there is an intermittent loss of power.
Checked the filter, and pre filter, new fitted.
Cant check the injectors but no smoke, tried to fit ones out of an 815 that I knew where good and i couldnt get it going at all. old inj back in and runing.
Sent to Main Stealer birmingham. But no EDC light so comp couldnt pick up the fault.
Put new sender uit in. Computer then seemed to say Brain was u/s. So I got another. Had it running, still got fault.
Had all loom out and checked for rubs. Put new cones in, had tank out and cleaned it. The many fitters I have had to look at it have told me the turbo is fine but when its revved the filter is emptied and doesnt appear to fill up quickly enough, I have to say I dont rate this last opinion.
Does anyone have any ideas at all.
I have runn out of options.
Carol.
Carol.
