92 R129 Stowage Compartments Lock
MarkyC71
300 SL
I have a 1992 SL300-24 the central stowage compartment between the seats only opens occasionally however I unlock the car. Is there an easy way of getting it to unlock or disconnecting the locking mechanism.
Iirc it's link to the central locking system, so I suspect the short answer is no. Someone with greater knowledge will be along shortly.
it works on vaccuum... you will need to pull up the centre console to then be able to get to the vacuum line... remove it from the lock and plug it with something suitable and airtight.
