- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, SLK55, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
The car is a 1994 SL500. It has been fitted with a Parrot hands-free kit (and an aftermarket immobilizer, but I think that has not affected the audio wiring); all bar one of the OE Mercedes connector plugs (see Note 1 in the attachment) are gone, and the wiring is a right bugger’s muddle of bullet connectors, twisted and taped connections, inline fuses and extra wiring using (by the look of it) odd bits of wire that were handy.
I’ve managed to isolate all the wires which appear to be part of the OE loom (the one with cloth tape wound around it), which also includes the coax cable for the aerial. The table shows what I found with a multimeter.
I’m fitting a Blaupunkt Santa Cruz radio/CD head unit; no amp, no CD changer, no ‘phone, nothing, except for the head unit.
It has feeds for rear speakers, but there are none fitted to the car. I presume/hope this will not be a problem if I simply set the front/rear balance to all front?
I have identified two permanent live feeds, one thicker than the other, an earth, an ignition switched live feed, and an illumination switched live feed.
I have no idea what the rest of the wires do. What I now need to find out (and I’ve tried until my head is spinning…) is which wires feed the front speakers, and which ones signal the aerial to extend and retract. Can anyone help?
