Mo420
- Apr 17, 2014
- Location
- Brunei
- '95 W202 C180, '97 W208 CLK320, '06 W639 Viano, '13 GT86, '07 RX300, '09 W211 E230, '15 Jaguar XF
Hello all!
Im looking to get some advice regarding our trusty old W202 Merc. Its an early (1995 model) C180, with the M111 engine that came without a MAF sensor. Its just turned over 300,000kms on the clock not so long ago.
Here's the issue - car would do a cold start during mornings just fine, however for subsequent starts after that, the engine will crank for a good 7-10 times (around 3-4 seconds) before it finally fires up, rather reluctantly.
Another thing is (maybe related or otherwise) the car seems to hesitate for a few seconds when taking off, for example, starting at a green light, with moderate to full throttle input, the car would jerk for 2-3 seconds as if the engine is cutting out, and then would only accelerate normally after that.
Both symptoms have started intermittently but now its progressively worse, now occuring every warm starts (long cranking) and when pulling away (jerking, hesitation).
I've trawled through the forums to no avail as most W202 C180s, unlike ours, are equipped with MAF which usually is the culprit in such scenarios. I doubt its usual stuff like plugs or coils since the car drives ok otherwise. We're currently leaning towards the fuel pump because recently the car ran out of fuel (our fuel gauge is bad hence unable to know exact fuel level) so we think probably some of the gunk thats settled at the bottom of the fuel tank is now clogging the fuel intake, does this seem like a sound theory?
We're planning to take the car into an indy's soon, so would like some ideas on what may be wrong beforehand if its possible. Car also isnt equipped with an OBD2 port so I cant get my scanner to pull out codes.
Thanks in advance for your responses.
Regards,
Mo420
Regards,
Mo420
