Just bought this car. It has hardly been used since July.
Using the switches in the front centre console all the windows go down as they should but none will go back up properly. Nothing happens when the 'up' switch is used & only by many, many repeated tries on the 'up' button do they go up at all & then in tiny (¼ inch at a time) movements. They only do the tiny movements some of the time in response to the switch being engaged.
It's equipped with push button digital display climate control. Is this unit meant to be illuminated when the lights are on? Mine isn't lighting up.
Any ideas what the problem could be?
