99 W208 230CLK dashboard issues
essex2visuvesi
98 230CLK
Hello everyone, this is my first post and it's a question.....
Has anyone seen this before?
https://www.youtube.com/watch?v=6g2BQOjTTXo
Started the other day after the car was parked all day in a car park (In direct sunlight as there was nowhere shaded to park. the lights flash even with the key out so I have had to remove the instument cluster fuse so the battery doesn't run flat.
The car itself runs fine
Any thoughts on what the issue could be?
Nosing around on tinterweb it seems there is a difference of opinion on wether I can just replace the cluster or I need it reprogrammed. If it needs programming what kit is required?
STAR diagnostic from Mercedes or an indie to reprogramme the cluster :D
