Danny DeVito
Asus p4p800se mb
Vista Home Premium
O2 mobile broadband E1752C
Broadband worked fine. Then the signal got gradually worse. While moving the usb stick to different ports etc something happened. I made a y cable using two certified hispeed cables, to add more power for the device. The stick works using this cable but only if plugged into the front usb ports. Any other ports and the pc tells me its malfunctioned. If i plug the stick direct into the port it still tells me malfunction. The stick works now without using the extra power from a second port. If i plug an extension cable into the hispeed cable it malfunctions. If i use any other extension cable it sees the modem but keeps connecting / dis connecting as if being plugged in and out .
The stick works fine in my laptop with any extension cable. The usb output is 5.15volts. I need to use an extension to get the signal.
If anyone knows a magic trick perhaps they can help ??
Danny
Vista Home Premium
Danny
