A class 160cdi fuel filter????
bigtee
hello i need to change the fuel filter, do i just fit the new one and the system re-fills the filter and self bleeds or do i have to bleed it?? just got the new filter it has 3 fittings 1 inlet at the top 1x centre fitting & 1x at the bottom probably return? im more used to plant with manual primer pump & bleed screw!!
Manually fill the filter otherwise you will end up with a flat battery before it fires up.
ok, there surley is a better method than this what do merc do?
See post #2..
