Hi
If anyone out there can help with this it would be very much appreciated.
My wifes A Class has developed a fault on the semi automatic clutch system. When you start driving it after a while "F" appears on the gear selection panel and you can not find any other gear.
If you turn the engine off for a while is seems to temporarily fix itself.
My local garage has had the car now for ten days and they can not tell us what the problem is.
They say they can replace the clutch but that will cost £700.00 and the problem might not be solved. It could need a new gearbox.
Any suggestions please?
