A Class
Discussion in 'Engine' started by crawfy58, Jul 24, 2002.
  1. crawfy58
    crawfy58 New Member
    14
    Jul 15, 2002
    Kent UK
    Car:
    A190
    I have a 190 A Class and would like to know where the oil filter is located at.
    Is it one of the modern types housed in a black plastic cover which is unscrewed from above and if so does it require any special tools.
    I have the vacuum oil suction tool on order.
    Thanks in advance,
    Iain
  2. Koolvin
    Koolvin Administrator Staff Member
    10,063
    Jun 1, 2002
    Staines
    Car:
    W168, W169 & S202
    I believe the A class oil filter is at the bottom, but if it *is* at the top then you need a special tool from MB.
  3. Koolvin
    10,063
    Jun 1, 2002
    Staines
    Car:
    W168, W169 & S202
    you can drain oil through the dipstick....
    if you do change the oil from the sump by unscrewing the nut - make sure u fit a new washer.
    TOOL: Hazet-2169 or 103 589 00 09 00 (mb part number)
    [​IMG]
  4. Howard
    Howard MB Club Veteran
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
Tags:
Share This Page
