i have a few problems with my new to me mb e300d first off i have been stalking on here for quit some time and decided to dive in with some questions
#1 my e300d glow plug light is wierd it will not come on untill after a minute and stays on for a minute and goes out but car will not start unless some fluid is sprayed into the intake i have checked the glow plugs and a couple are bad and i am checking the relay and read that it should show battery voltage for 20 seconds (mine shows battery volyage as long as the key is on
#2 the temp gauge does not move at all and i was wanting to find out how to test the system for a soultion
#3 my fuel gauge is not acurate it is empty when it shows about 3/8 tank (ie between 1/4 and 1/2 tank ) i dont know where it stops when i fill it because i have never filled it all the way up thinking i might have to remove it to fix the gauge by the way the tank is located right behind the rear seat
