There is no way I would go 17K without an engine oil change. I will be well contaminated with Derv by that time.Can someone tell me what the A service interval is on a C Class 220CDI
I thought is was a variable mileage +-17000 or 12 months which ever is sooner ? - Maybe I'm wrong ?
Cheers
Adam
Thing is, yesterday it said about 4,500miles to the service.
This morning it then said 30 days to service.
Tonight it said 29 days ??
I bought the car new at the end of April 2007 ?
Cheers
Adam
Maybe it's over cautious, but I would ask them to write something down to confirm that, just to save any confusion later. If the car were to breakdown, the Mobilo guy might not be very happy if the car appears to have missed a service. I'm pretty sure the system is just reset when serviced so being "late" won't mess things up in the future.Thanks for the replys...I spoke to 2 different dealerships today who gave me 2 different answers. One said it's normal and just requires a service, the other said as I originally thought and Rory mentioned that they didn't reset it on the PDI. - this was the dealer that did the PDI.
They said sorry, don't worry, just run it till April, then get it serviced.
Won't it then think I was 2 months late for a service, or doesn't that matter ? - only just thought of that.
£245 is normal, £170 is very cheap. Make sure it includes 229.5 oil fully synth, although I'm not sure if that's so important if the car is on fixed intervals (it's necessary on the variable interval to get the maximum mileage between services).Also got 2 quotes from them for the A service, £170 inclusive of parts, labour, vat and £245 from the other - quite a difference - both main dealers.
That's impossible. Diesel and petrol engines will always allow fuel vapour to escape past the piston rings into the block. Even on new low milage engines.Some cars go upto 22k, and Audis can go 30k.
No evidence of contamination.
You can smell it in the oil when you drain it. That's enough evidence.
And where did he serve his apprenticeship. Was he a Welder ?There was a post from someone either here or the other forum who had the oil from Sprinter analysed at 20 odd K miles and the report said it was fine and would have been OK for longer.
