Celicasaur
- Dec 17, 2011
- W212 E63 AMG PP
Right folks, so I'm at a crossroads with my A124 which i mostly hate and only sometimes like.
The 4 speed autobox is pants and always has been. It has a horrid flare from 1st to 2nd and a light one from 2nd to 3rd. It also now hits a fuel cut and doesn't shift at redline if I go full throttle, then if it gets upset, it goes into some kind of limp mode and doesn't want to go past even 4000rpm at medium or light throttle. None of the little tricks with the vacuum lines or that spring or anything else will remedy this...seems like it has issues internally, but I don't know the platform too well, so can't be confident as to what it is.
Any experiences with a rebuild transmission and costs that I should brace myself for? I suspect the gears and synchro's are the the issue, so it will be little bits inside like the...I dunno...little bits? OR should I try to find one from a breakers yard, but at a risk that it might only be slightly better than what I have now. What I ideally would like is an experience close to oem with the transmission.
Lastly....any recommended places where I can trust to take care of my car and not bend me over, somewhat close to the London area? I live in West London.
