hi got an A160 1999 just recently.got it very good price but has a misfire when warm and hesitates when accelerating,idling eratic not smoking at all but smells very much of the cat.put set of plugs in and no difference.had star test done and no faults found.lot of people say could of been coil pack or ecu/maf unit but i have now done a compression test and no.1 pot is reading approx 210lb psi no 2 the same no.3 the same but no.4 only 50lb psi and that took a bit to get up there.i take it i may have a valve problem on no.4 pot.can anyone let me know what parts i will need to rectify this and is it an engine out job and is it very involved.can i try a liquid decoke on this model by putting redex in air intake and running engine faster than idle speed till the smoke clears.only heard of this being done on mondeo zetec's with sticky valve problems and seemed to cure them most of the time, wonder if this may help with A160 or not.any help and advice very welcome thanks for looking.chipsraff
