Tezz
V belt got taken out by alternator pulley, was very worn so no part number on it
Iv replaced the alternator pulley and got part number from EPC, matched it to old one and its identical. chassis number WDD1690072J287535
Also replace the lower guide pulley again got part number from EPC and matched it up to original as there are 3 different sizes on my skate one 65mm, one 70mm and one 76mm
Order a Gates belt using part number A0029934896 17.8x1745mm, checked part that arrived and its 5PK1745 so should be the same length.
I have a flat bar with a 15mm crows foot on it so can move the tensioner a fair way
Problem is no matter what I try I cant get the belt over compressor it seams way to short
Its a bit hard to see, but appears to be on the pulleys correctly and routed the right way according to my WIS
Any ideas ?
Tezz
Any ideas ?
Tezz
