Tezz
Front o/s spring snapped on car, was lucky happened just as I was getting home, the springs snapping on theses cars seams very common.
Theres a vid on you tube
Got a pair of matched springs (German made) for £25 delivered, Mercedes I believe say you can change 1 only so long as it exactly match's what's on car, but I was always of view what you do on one side of suspension breaks ect you do same on other.
I changed the broken 1, put all back together took for test drive to make sure all settled in and their was approx. 10-15mm difference in ride height from side to side, new spring sat higher, so def needed a pair of springs in my case
Not a technically demanding job, so long as you have all tools and sockets and can get both wheels of ground at same time
Pay attention in Vid as you will need a 21mm socket with an external hex on it and a long 7mm Allen key to remove top nut, I used a 21mm spark plug socket as that had external hex (most do) and a long 7mm 1/2 drive Allen key I have for some break jobs. I don't own a impact wrench so my long 3/4 breaker bar and 21mm impact socket got the nuts of bottom, 17mm for drop link and an Allen key in middle to stop it spinning. Top 3 nuts came off easy they are E14 Torx
compressing the springs took a few attempts as I was using a pair of spring compressors I had already, not the easiest things in world to use. shox looked ok, no leaking or damage I could see to top mounts, damping seamed ok before spring boke, so I reused them
For £25 im pleased, will let you know how it rides.
I have no idea of quality of springs other than what they posted in description , CD Coil Springs are manufactured to original equipment quality ISO and TUV standards using the latest oe-specification spring steel and benefit from advanced protection coatings against corrosion.
But even MB originals seam to break quite offen
I will see how t goes and may replace rears as well so I know they at least have a few years in them.
Tezz.
Tezz.
