Zerohennie
- Aug 5, 2012
- A190
Hi Guys, I have some problems with the Wife's 2000 Mercedes A190, auto, petrol, when it is cold say if it is standing overnight in the garage it takes forever to start, it cranks over about 7 times before starting, it first sputters a bit on say the 5th turn, then on the 7th it wil start and then idle, work I have done so far:
replaced brake switch
cleaned throttle body and mass air sensor
replaced crank shaft positioning sensor
replaced torn breather pipe
had all the errors cleaned previously before the CPS replacement , before and after this is the errors that came up:
Lambda adaption 2 03 at maximum control stop
Oxygen sensor 1 (In front of CAT) 06 voltage too low
Lambda adaption 01 at maximum control stop
Engine Oil sensor: oil quality 00 signal improbable
CAN signal: gear identification switch 09 faulty
Guys I need help as soon as humanly possible as this is the Wife's car and needs it to drive our Son to school and back etc.
Please help, I must ad when it has started up and running it runs smooth, no problems, no idling problems no errors on dash , I have measured the batteries voltage and it is all good over 12volts
Thanks guys
Thanks guys
