ACID
Hi Guys
As Some of you may know that the A45 ECU has been cracked and Tuned By Big Fish Tuning & MSL Performance . Here is what we have achieved so far :
This has been a joint project between BFT and MSL and is the First in the UK. Early day figures of mapping was producing 358 whp and 419 lbs torque and numerous logging, development we end up with 380 whp and 443 lbs torque to the Wheels.
Compared to tuning box torque is produced much earlier and much smoother. Peak of 40 lbs torque more than the tuning box. 25 whp peak more than tuning box.
VMAX is off and 2nd lambda sensor has been mapped out as well.
The Car GLA 45 :
The Car had the Following Fitted when Tests were being carried out
Weistec Down Pipe and IPE Rear Valve System.
Also the DP does not make much power at all but helps with better Spooling and Response.
Standard Map Vs. Modified Map
Tuned Remap Vs. Tuning Box.
The Water Temps were also been monitored via the OBD port and these speeds are not expected on the Road as this was to show the V max only.
[YOUTUBE]yBbCui5vlHs[/YOUTUBE]
If anyone has any Questions please contact us.
We can Provide a 2nd ECU tuned if people are worried about Warranty.
ACID
MSL Performance
0121 772 4455
The Car GLA 45 :
ACID
MSL Performance
0121 772 4455
