JohnC said:I know I'm a tad late - but the same happened to me (about £10pounds-worth went in) I topped the tank with diesel - and for the next couple of fills I kept the revs down and drove like it was icy and this was in a 1999 250TD with 70,000 on the clock - the engine is fine!
Dieselman said:WARNING!!!!!!!!!!!!!!!!!!
The new high pressure pumps fitted to MB CDi engines are not tollerant to petrol.
There have been many cases of knackered pumps even when the petrol has been diluted. This knackers the whole fuel system due to steel filings.
DRAIN THE TANK!!!!!!
The old adage of diluting the petrol and adding lubricating oil is not sufficient for the close tollerance, high pressure pumps now.
Also add some engine oil or two stroke to your first full tank of diesel as extra lubrication.
I've seen a new Ford Mondeo TDCi knackered on it's first day on the road. Only did something like 10 miles.
grasmere said:It seems that a different nozzle end for each fuel type would be easy enough, square, triangle, round or big buttons at the pump that you have to press first DIESEL / PETROL
..."will it be the square nozzle, the round nozzle or the arched nozzle today then "
grasmere said:exactly dittrich, thats how basic it really is isn't it
Playschool have been doing it for years, you'de think multi billion £ oil companies would learn something . . .
