stamyspeedy
- Sep 9, 2013
- Mercedes vito 639
My 639 vito failed its mot due to these faults. I found on the net that this is quite common, I also found alot of people fixed this by replacing the brake switch (on the break pedal) I did this and it fixed my disco dashboard :bannana: this is a very quick simple and cheap repair (£17.50 from my local bells Mercedes) remove the black plastic panel from above the pedals, 2screws and 2 plastic rings. You will be able to see the switch on the pedal now, disconnect the wire to it and press the clip in, turn it 90 degrees CLOCKWISE! It should just unclip now, VERY EASY FIX! Hope this helps someone else
