This worked for W208 CLK 320.
How to reset the ABS, BAS, & the ESP warning lights.
First,
To remove the brake warning light:-
Place and hold your foot on the brake pedal then put your key in the ignition and start the car. Wait a few seconds and the light should not come on. . Now release the brake pedal, if the light comes on instantly, it’s probably the switch.
You may have to repeat this 2 - 3 times.
Second,
To reset the system codes:-
Start the engine
Turn the wheel all the way to the left
Turn the wheel all the way to the right
Turn the wheel back to center position
Turn of the ignition, pull out key
Start the engine
First,
Second,
Start the engine
Start the engine
