ABS/EPS Warnings on display since Brake Rebuild
Boffin486
Aberdeen
W203 CL220 Sports Coupe SE, C280 Avantgarde SE & Also Audi A4 B7 Avant Quattro & 3 Calibras
Hi folks - I have completely rebuilt the braking system on my Coupe but since the MOT (it came on during the Test) the ABS/EPS warning is on the display.
See previous thread : Full Brake Rebuild & Upgrade | Wheels, Tyres, Brakes & Suspension
I have actually replaced everything - all 4 Calipers & Disks as well as the ABS sensors all round but the warning persists. What am I missing? does the warning actually mean anything or does it just need to be reset? The car is due MOT again so I need to fix this pronto. Is there a procedure to be followed with the ABS pump/distributor (ie cycle all the valves electronically & bleed the system)?
Any thoughts folks?
Replaced all 'ABS' sensors. ? Not shown in your first thread. What ABS sensors did you replace ?
All 4 of the sensors in the hubs front and back.
Get the codes read , at least it will point you to the correct corner for further investigation.
K
some DTF need a code clearing after replacing failed component. Others self clear.
Clear codes, lock to lock, small drive.
See if fault comes backS
Ta for that, I'll borrow a code reader & see if I can get a fault code but I think Generic code readers cannot access ABS readings.
