ChrisMcG01
Hi everyone, this is my first post, but it’s a tricky issue. I’ve been able to fix most things easily enough.
I have a UK 2000 MB CLK 320 (208.365). I have an ABS fault, but when I plug in my little “Super. Computer”, I can’t get a wheel speed reading to see which one of the sensors is the issue. I can clear the codes to re-set the fault on the dashboard (ABS light comes on with power on, but goes off upon ignition) which is great, because then I think I can plug in my machine and get wheel speed readings, but the second I enter the ABS system on the computer, the fault light comes back on again effectively switching the sensors off and meaning that I can’t get wheel speed readings.
Has anyone encountered this before? If so, how did you deal with it?
Help?
Help?
