ABS problem???????
merclover
Wonder if you can please advise me. I have a 1997 C180 and it has been off the road for 3 months while I was away from home. I have started to use it again today but the ABS warning light will not got out after I turn the ignition on and while I am driving. This never happened before I took it off the road - is there anything that I should check before I leave it into a garage and pay a lot of money.
I would appreciate any advise
If I recall correctly I think the ABS needs a minimum voltage of 10.5 volts, I could be wrong but I'd check your battery has enough juice.
S.
