Broadleybenz
Hi, the brake shield had worked itself loose and got jammed down the back of the caliper so I pulled it out
Since then I’ve had abs fault/ esp fault / service brake fault.
I thought it may have nicked the abs sensor so I replaced that and deleted codes.
fault re appeared after a few feet what else could it possibly of damaged or be?
thanks for any help
thanks for any help
