You would need to identify which one of the four sensors is faulty, if indeed it is a sensor fault. You could have faulty eductor rings (i think thats the name), ABS pump, or ECU fault.
Get the codes read as it will clarify this.
MB dealer want 20 minutes labour time to read the codes, but there are plenty of reliable Indys around that could do the job.
