shirleydrive
- Feb 8, 2013
- E320 w210 1998 61K
With summer hopefully approaching , thought I would test the AC. No cold air so interrogated climate control unit. . Most readings looked OK ish except No 7 (refrigerant pressure) This read 04 (4 bar?) No difference whether engine running or not. Am I right in assuming that compressor won't run due to low refrigerant pressure?
Pulled trouble codes but none present. Display indicated FF. Expected to see B1241 (refrigerant fill)
Here is the data list I pulled with ignition on but engine not running :-
1=16
2=14
3=36
4=35
5=50
6=49
7=04
8=20
Quite prepared to have system refilled if that's what it requires, but don't want to throw money away. Any advise would be much appreciated.
Thanks, Mike
1=16
2=14
3=36
4=35
5=50
6=49
7=04
8=20
Thanks, Mike
