Aclass wheel help
rubbachicken
hi there
i am looking to find a set of steel A class wheels preferably the type with 10 or 12 or so hole around the wheel
i have tried a google serch for mercedes breakers and fall asleep before finding anything useful from the results, there must be a mercedes breakers out there some where can anyone help me
Try the "favorite section loads" of breakers in there,Or even mercman in the classifieds.
can anyone confirm whether c180 wheels will fit an A classs ?
as far as i know, this is the dimentions for merc wheels, i'm afer the A class wheels as they have fewer large holes around the rim, most of the other rims i have seen have 20 or so, 1" holes around the rim, this is not what i'm looking for, also i need the offset of the A class wheels
MERCEDES
Model P.C.D. Offset C/Bore
All (except below) 5 x 112 35...42 66.5
SL models 5 x 112 18...25 66.5
A Class, Vito 5 x 112 45...50 66.5
Sprinter 5 x 130 45
As far as I know these wheels will not fit the A class as the wheel offset is way too different.
i guess i was not so clear, the "can anyone confirm" was supposed to be a quote from howard's reply
anyhow i'm after steel A class wheels, they are needed for a project i'm working on, i have a '59 vw split screen van, i spent quite a wedge on a set of wheels for the van only to find that they only have a 6mm offset, as opposed to the 35 standard, i have lowered the van about 6" from the factory height i need the big offset of the A class rims so that i don't need to narrow the fron axle, as the front wheels chafe on the inner wheel arches, most steel merc rims have 20 or so 25mm holes around the center, i have seen an A class with steel rins with only 10 or so bigger holes around the center, sorry about not being merc motivated but this van is nearlly ready but won't go on the road cos it ain't got no wheels :)
If all els fails, try the dealers mate. They may not be "cheap" as such but they may not be as ££££££££££££ as you might think.
Stu :)
these are what i'm after, A class steel rims, sorry about picture taken on camera phone
