Acronyms of Diagnostic Codes
Hi my car has a fault. Basically I was driving my A class automatic 2013 car and then it lost power. The dash board said without changing gear consult workshop. I had a diagonstic teat done. By a not very good mechanic.
The codes showing are 07e600- park pawl cannot be released
071564 the Rpm sensor “turbine wheel has an implausible signal
C073200 one or more signal sent from the CAN bus is implausible
C05c200 the can message from control unit N2/10 (supplement restraint system) is faulty
Can any one please shed some light on this.
The car currently starts but doesn’t drove. It’s a semi automatic car.
Please can someone help me and tell me what the fault is and how I fix it.
Thanks in advance
post: 996444, member: 22986"]Hi All,
I hope this helps to decipher the DTC's codes you may get,
Regards,
Scorpie
Mercedes-Benz Technical Acronyms
These acronyms are related to Mercedes-Benz vehicles. You can see these acronyms
while using diagnostic software and automotive diagnostic tools like OBD scanners or other
equipment.
4MATIC – 4 Wheel Drive
TC – Transmission Control
A/C – (Automatic) Air Conditioning (Automatic)
A/C – (Tempmatic) Air Conditioning (Tempmatic)
AAC – Automatic Air Conditioning
AAM – All Activity Module
AB – Supplemental Restraint System (Airbag)
ABS – Anti-lock Brake System
ACSR – Automatic Child Seat Recognition
ADM – Automatic Dimming Inside Rearview Mirror
ADS – Automatic Damping System (Suspension)
AIR – Secondary Air Injection
AKR – Anti-Knock Regulation
AP – Accelerator Pedal
APS – Auto Pilot System
AS – Antenna System
ASD – Automatic Locking Differential
ASR – Acceleration Slip Regulation
AT – Automatic Transmission
ATA – Anti-theft Alarm System
BA – Backup Assist
BARO – Barometric Pressure
BCAPC – Barometric Pressure-charge Air Pressure Compensation
BDC – Bottom Dead Center
BM – Base Module (Master Ecu Controller)
BPC – Barometric Pressure Compensation
CA – Closing Assist
CAN – Controller Area Network
CC – Cruise Control (Tempomat)
CCM – Combination Control Module
CDC – Cd Changer
CF – Convenience Feature
CFI – Continuous Fuel Injection
CKA – Crank Angle
CKP – Crankshaft Position
CL – Central Locking
CLUS – Instrument Cluster
CMP – Camshaft Position
CNS – Communication and Navigation System
CST – Cabriolet Soft Top
CTEL – Cellular Telephone
CTP – Closed Throttle Position (Idle)
CTU – Central Triggering Unit
DAS – Driver Authorization System
DFI – Electronic Distributor-type Fuel Injection
DI – Distributor Ignition System
DM – (USA) Diagnostic Module (Emissions)
DTC – Diagnostic Trouble Code
EA – Electronic Accelerator
EAG – Electronic Automatic Transmission Control
EATC – Electronic Automatic Transmission Control
EBR – Engine Brake Regulation
ECL – Engine Coolant Level
ECT – Engine Coolant Temperature
EDC – Electronic Diesel Control
EDR – Electronic Diesel Regulation
EDS – Electronic Diesel System
EDW – Anti-theft Alarm System
EFP – Electronic Accelerator
EGR – Exhaust Gas Recirculation
EGS – Electronic Transmission Control
EI – Electronic Ignition (distributorless)
EIFI – Electronic In-line Fuel Injection
EL – Exterior Lighting
EMSC – Electric Mirror, Steering Column Adjustment, Heated Mirrors
EPC – Electronic Power Control
ERE – Electronic In-line Fuel System
ESA – Electric Seat Adjustment
ESC – Electric Steering Column Adjustment
ESCM – Engine System Control Module
ESP – Electronic Stability Program
ETC – Electronic Transmission Control
ETR – Emergency Tensioning Retractor
ETS – Electronic Traction System
EVAP – Evaporative Emission Control System
EVE – Electronic Distributor-type Fuel Injection
EZL – Distributor Ignition System
FAN – Fanfare Horns
FFS – Frame Floor System
FOM – Folding Outside Mirrors
FP – Fuel Pump
GIM – Governor Impulse Method
GM – Base Module (Master Ecu Controller)
HAU – Automatic Heater
HCS – Headlamp Cleaning System
HEAT – Automatic Heater
HFM – Hot Film Engine Management
HFS – Hands Free System
HHT – Hand Held Tester
HM – Heated Mirrors
HORN – Horn Signal System
HS – Heated Seats
IAT – Intake Air Temperature
IC – Instrument Cluster
IDC – In Dash Controller
IFI – Electronic In-line Fuel System(diesel)
IFZ – Infrared Remote Central Locking
IL – Interior Lighting
IR – Infrared
IRCL – Infrared Remote Central Locking
IRM – Inside Rearview Mirror
ISC – Idle Speed Control
KE – Continuous Injection System (Cis)
KFB – Convenience Feature
KI – Instrument Cluster
KLA – Air Conditioning
KS – Knock Sensor
KSS – Knock Sensor System
LH – LH Sequential Fuel Management Bank 1 (1-6 or 1-8 Cylinders)
LH2 – LH Sequential Fuel Management Bank 2 (7-12 Cylinders)
LHS – Left Hand Steering
LLR – Cruise Control
LOC – Low Compression
LS – Loudspeaker System
MAF – Mass Air Flow
MAP – Manifold Absolute Pressure
ME – Motor Electronics
MIL – Malfunction Indicator
Lamp – (Check Engine)
MSC – Mirror, Steering Column Adjustment, Heated Mirrors
MT – Manual Transmission
MVA – Manifold Vacuum Assist
MWH – Main Wiring Harness
NS – Network System (CAN)
O2S – Oxygen (O2) Sensor
OBD – On-board Diagnostics
OC – Oxidation Catalytic Convertor
OCP – Over-head Control Panel
ORM – Outside Rearview Mirror
OSB – Orthopedic Seat Backrest
PL – Power Lock
PML – Speed-sensitive Power Steering
PMP – Partial Intake Manifold Preheater
PNP – Park/neutral Position
PS – Power Steering
PSE – Pneumatic System Equipment
PTS – Parktronic System
PW – Power Windows
PWM – Pulse Width Modulation
RB – Roll Bar Control
RCL – Remote Central Locking
RD – Radio
REST – Residual Engine Heat Utilization
RHR – Retractable Rear Head Restraints
RHS – Rear Heated Seats
RPM – Revolutions Per Minute (Engine Speed)
RST – Roadster Soft Top
RTG – Retractable Trunk Lid Grip
RTR – Remote Trunk Release
RV – Roadster Soft Top
RWD – Rear Window Defroster
SBE – Seat Belt Extender
SLO – Starter Lock-out
SMS – Service Microfiche System
SOR – Seat Occupied recognition
SPS – Speed-sensitive Power Steering
SR – Sliding/Pop-up Roof
SRS – Supplemental Restraint System (Airbag)
STH – Stationary Heater
TB – Throttle Body
TC – Turbo Charger
TCM – Transmission Control Module
TD – Speed Signal (Time Division) (EZL)
TDC – Top Dead Center
TIC – Transistorized Ignition Control
TN – Speed Signal (EZL/AKR)
TPC – Tire Pressure Control
TRAP – Trap Oxidizer
TS – Towing Sensor
TVV – Tank Ventilation Valve
TWC – Three Way Catalytic Convertor
ÜRB – Roll Bar Control
VAF – Volume Air Flow
VSS – Vehicle Speed Signal
WOT – Wide Open Throttle (Full Load)
WS – Wiper System[/QUOTE]
Thanks in advance
hi Kay,
I am facing same cods to, have you abele to fix?, what was problem ?
Regards,
Scorpie
equipment.
AS – Antenna System
BA – Backup Assist
CA – Closing Assist
CDC – Cd Changer
CKA – Crank Angle
FAN – Fanfare Horns
FP – Fuel Pump
HM – Heated Mirrors
HS – Heated Seats
IR – Infrared
KS – Knock Sensor
MAF – Mass Air Flow
PL – Power Lock
PS – Power Steering
PW – Power Windows
RD – Radio
TB – Throttle Body
TC – Turbo Charger
TS – Towing Sensor
WS – Wiper System
[/QUOTE]
My 2010 MB E class 2.1 OM651 Diesel Automatic is showing the following code and MSG:-
UO42908. "Implausible data were received from the steering column module. There is a signal fault or the message is faulty.
DTC Status:
Stored.
Anyone know what this means? Car driving perfect, no dash warning lights etc.
^ If its a stored code, clear it and see if it returns. Some cars have dozens of stored codes but no faults.
I would take a guess that at some point you have had low voltage and the error was caused by this.
It's only current faults you need to be concerned about.
Thanks AMgeed, I'll clear it and see how it goes. I scan regularly, but I never saw this one before.
