Hi All, I have a W218 2015 CLS Shooting Brake showing the Active Blind Spot Assist / Lane keeping Assist Inoperative on the central dash board screen.
My assumption is that I have a faulty Blind Spot Assistant Radar Sensor...WHY
The active PARK assist (white arrow against the BLUE box) works on the left, but not of the drivers side.
The active lane assist and distance to car in front cruise control all work fine, as does the assisted steering.
My local garage did an analysis and suggested a communication issue with "RADAR 5".
I've looked under the rear bumper and can see a left, right and central Radar Sensor, black box with white on one side. I've removed Left and Right and they look good, no obvious cause for fault.
The front central Radar Sensor, behind the badge I believe is a long distance sensor and looks fine.
Following this train of thought, all left to check is Front Radar Sensor (left and right). What i can find is places online who will sell me a new one, however I can not see anywhere online showing diagram locating on the W218, where these are... On different models I can see these but am reluctant to start major strip down just to see if I can find them.
Any advice - possibly RADAR 5 means something to a guru, or maybe a parts diagram can confirm if indeed the W218 has a have front left and right...maybe accessible via the wheel arch. My intention would be to locate and inspect hoping to find an obvious fault.
After this the question would be is it a fit and replace part or do i need to re programme the new sensor. Other threads suggest once identifying the damaged part, finding one with similar part numbers (exactly the same) would allow plug and play... This is maybe a step to far but hoping my long explanation triggers interest from someone with previous knowledge on this. Sort of like problem solving on previous cars, however this one is really stumping me.
Any help, knowledge or support would be appreciated....
