Hi guys,
During the last 2 months i am struggling with issues with my Mercedes e220d - year:2015.
The issue initially started with the engine yellow lamp, which after inspection ended up to be an issue with the back Nox sensor. I ordered a new Nox sensor and waiting to arrive.
In the meantime, an Adblue message appeared which showed up that my Adblue is almost empty and needs to be refilled. My mechanical engineer added 10L adblue and the message disappeared but but after 2-3 days a new message appeared that "AdBlue: Your engine will not start in 800km".
So then, I bought 20 more litres of Adblue and i filled the tank to full. The message is not disappeared.
Now, when the engineer connect it to diagnostic he gets:
P13DF09: The Adblue(R) system has a malfunction. There is a component fault
P229F09: NOx sensor 2 (cyclinder bank 1), has a malfunction. There is a component fault
Even if he deletes the P13DF09: The Adblue(R) system has a malfunction. There is a component fault then the "AdBlue: Your engine will not start in 800km" disappears for a while and come back after a while.
My question now is:
1. Is there a chance that the Adblue message to not be deleted properly that's why it appeared again?
2. Is there a chance that the Adblue message appeared because of the faulty nox sensor?
3. Nox sensor is arriving soon, but i am wondering if the issue resolved or if i will have to replace also other parts from Adblue system.
What is your opinion? Anyone, faced similar problems ?
My question now is:
