Add Heating Radiator in Garage / Any Plumbers offer Advice Please ?
OP
OP
pmcgsmurf
pmcgsmurf
Stirling, Scotland
E55 AMG W211, E250 Sport W212, E220 Avant. W211 (and some Imps)
My Magnaclean arrived from Amazon, will get it fitted whem its warm and dry enough yo get the little car out the garage.
OP
OP
pmcgsmurf
pmcgsmurf
Stirling, Scotland
I'm just going to fit this myself.
Noticed it's just compression fittings and cutting a section out of the return pipe so noce easy job.
Happytalk73
South West Scotland
119 Vito / C300h PP Estate.
To keep the heating costs down, I've just taken it to the next level. I've ordered a new old stock Soviet Ushanka hat, 1980s vintage. I can get away with that sort of thing in my own home. It will be ear flaps down too! It's the mid-grey fur and grey tweed effect, rather than Cossack black bear fur effect.
If it's good enough for Siberian winters, it should be fine in my house 😄
I’m much more interested in a photo of @MrGreedy’s hat in-situ. 😁
MrGreedy
South West
E350 CDI
Whilst we wait for pmcgsmurf's install pics, I can bore delight you with some relevant filter shots 😂
I had a new boiler installed right before Christmas (thank God I found someone with a slot at short notice, otherwise it would have been 11 days without heating or hot water).
The previous boiler was about 12 years old, but nearly all pipework and radiators in the house are less than 2 years old due to major rennovations.
During install, the plumber put in an Adey MagnaClean Atom filter, on the return 22mm pipework just before the boiler.
Following my earlier post about regularity of cleaning the filter, I'm currently in a weekly cleaning cycle. I'm shocked at how much crud is pulled out of the system every week after something like 6 filter cleans in a month!
All the metallic oxide particulate would be getting chewed up as it passed through the pump.
Filter casing removed with magnetic filter before cleaning earlier today.
You pull off the light grey plastic tube that covers the magnetic filter which removes 99% of the oxide crud and wash under the tap.
Magnetic filter removed and washed under the tap and wiped clean before reinstalling
W1ghty
Sunny Essex
E320cdi and CLK200
They are some large pieces , do you have old rads ?
Happytalk73
South West Scotland
What about ya hat? 😟
