BIG_G_1979
Hi guys so I have found out that the front shocks can be adjusted to alter ride height of the car via a locking ring under the spring cup. Can I assume the higher you raise the cup the lower the car will be? Ie shortening the length of spring? I understand that the spring and shock will need removed prior to adjustment but was wondering what to set locking ring at thanks
