IFFY100
Just picked up a 50k 2010 cls and want to do all the necessary servicing to it. So as a starting point I will detail the things I think need to be done and please add to the list as required:
I cant really think of anything else that needs doing as part of maintenance.
Also advice on a workshop manual would be good. Found some stuff on the internet but not sure. Sadly Haynes do not do a manual for this car and neither do bentley.
Lastly looks like the window regulator has detached itself from the glass, is there a diy for this or a repair that will last? tag tie repair on an e46 bmw works perfectly!
- Oil change and filter (5w30 every 10k or per year)
- air filter (every 10k or per year)
- brake fluid every two years
- what fluid do I need for this?
- What is the procedure for this, i.e the same as it is on many older car?
- Fuel filter (every 30k)
- what is the procedure for this? Seems simple as unbolting the part. I would of have thought that a fuse needs to be removed etc
- Diff fluid (30k)
- simply drain and refill till diff leaks fluid from fill bolt.
- is there a product that you put on the thread of the fill/drain bolt
- coolant (two years)
- 7g tronic fluid (please discuss this in terms of change frequency and procedure)
- Throttle body cleaning (any info on this)
- maf sensor cleaning (30k or 2 years) is it safe to do this?
- Steering fluid (30k or 2 years)
