In the main RUST! Mechanically they are pretty sound (subject to the usual checks) but have a good look around the bodywork. The worst of the rust can be difficult to spot. It usually is due to water leaking into the car via the heater box. Open the bonnet and you will see a black cover near the bulkhead with screws attaching it. Open it up and take a look. Rust here will be expensive to fix.
Ok will do cheers
Would you say that engine quite strong on the 280 ?
Im surprised looking at your other cars, you would be looking at a 280 !
Surely a 500 is more you !
The main problems with 107's is rust, and rust. Check all the drain holes are clear, even take a watering can along to check.
Mechanically fairly solid, at the age they are now, rubber mounts, seal and bushes perish. But most parts available.
Interior and exterior trim are expensive, so worth checking its all intact.
Im sure the 280 engine will be OK, just not as exciting as a 500.
