IFFY100
Some may know I have recently serviced my gearbox which went smooth and well. However I was having an issue before servicing the box, which is why I serviced it sooner rather than later (also the car was on 55k and I suspect had not had a box service. Anyway the issue I get is soft hesitation at very low rpms and speed or when I'm driving like a granny. This happens no matter hot or cold. But does not happen at all when spirited driving takes place, which leads me to think the problem is not with the gearbox. Interms of service, so far I have done the following : engine oil, diff oil, gearbox oil, oil filter, air filters, coolant, brake fluid,steering fluid. What else should I do? Obviously some of the services noted where not to rectify this issue.
