Hi
Went to look at a 1992 230E saloon today. The Body work was in excellent condition for the Age & Mileage 150000. Had a look around under the engine before starting the Car which has been stored in a Garage for the last couple of weeks. Did the usual checks and found what looked like Oil in the Coolant expansion Tank. I say looked like but I'm not sure was a brownish colour and seemed a bit thicker than normal anti freeze solution.
Anyway their was a bit of OIl around the top of the engine right hand side above the Distributor hard to tell where it was coming from as the Air Filter cover was in the way.
Car started without a problem let it run for about 5 minutes checking the Temp gauge OIl Pressure Gauge showed plenty of pressure.
Had a test drive of a couple of Miles. Drove very well no untoward noises from the Diff or elsewhere. Got back checked the Temp gauge reading around 80.
So I'm wondering was it Oil in the Water ? would It be a safe Buy ?
any suggestions would be most appreciated
Regards
Ian.H
Regards
Ian.H
