Advice Please..
Jasperblue
Lancashire
C270 Cdi Avantgarde Auto
I have a 2004 C270 Cdi Avantgarde 4dr Auto (240k):
The car has been running great until I stopped after about a 10 mile run. I went to restart the car the engine management light came on..(which it had done previously and I went to clear the fault via code reader. This time it wouldn't clear). The car started fine and runs fine on idle, however, it wont accelerate at all. It also came up with another odd fault (on the display, not as a fault code) which was Check Engine Oil and take to Garage. I check the oil an a weekly basis (the car uses very little oil although its done 240k and regularly serviced and its not leaking any oil). There were four codes (as far as I can recall, the car is with my mechanic at present) two relating to Throttle Position sensors and I just can recall the other or cant post them at present as I don't wish to bother him. Has anybody had a similar problem...I'm really stuck at presnt as I need the car. Any help/advice would be greatly appreciated.
Does you mechanic have STAR?
It's been 3hrs, any update on what he has found?
Please use correct section and stick to one thread instead of creating multiples. Thanks
Moving.
