mapleleaf
- Dec 4, 2002
- Location
- Hinckley, Leicestershire
- 2022 GLC 300 estate- replaced 2018 Gle 43 AMG Night - replaced previous 2015 E63 AMG
Hi All
A friend is producing a school play ( we will rock you) and needs to be able to send wireless stills and some footage from a laptop to a fixed position projector. Connecting to a vga input on the projector. The distance between the devices is approx 10 metres.
I believe there is a strong WiFi signal in the hall where the performance will take place and wondered if anyone had any thoughts on this adapter:
http://www.optoma.co.uk/uploads/brochures/WPS-3%20Wireless%20Adapter-B-en-GB.pdf
If the WiFi isnt strong enough then the other options are
a) a dedicated wireless connection but not sure if 10m is to far for that to work. or
b) A hard wired connection - but to route the cable out of sight and safely it would need to be around 30m in length - would this be an issue regarding signal loss at all?
Is there perhaps a better way than any of the above?
All comments welcome
tia
tia
