i have just put a deposit on a 2003 C180k advantgarde estate with sports pack. Have i done the right thing? and what can go wrong and what should i look for before i hand over the balance.
Hello. I have a 2003 C180K (built Nov 2003) Avantgarde estate. Bought it new with my own cash. Full MB history. It now has 50K miles. This is a summary of the warranty work it has had not in any particular order.
1. New exahust due to chronic corrosion.
2. Rain sensor failure.
3. CAN bus errors - tiptronic box would not shift.
4. Complete new front suspension - new wishbones, new roll bar, bearings, bushes, track rod bits and bobs. Car was fitted with a modified wishbone kit. Front suspension is a known W203 weak spot on 2003 and earlier models.
5. Wheel bearing failure.
6. Driver's door electric window failure.
7. Corrosion on underside of front wing.
8. Other front suspension issues - car leaning 3 ins lower than pass side.
9. Rear discs badly scored - replaced as goodwill by MB.
10. Lacquer defects from new.
Good bits: Engine is bomb proof. C180K is the best in the range - glass smooth and good economy.
4th year B service was £980.
You MUST get a warranty You will need it.
Good luck.
