SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
Hi
I discovered my rear wheel bolts have been tightened REALLY tight by the garage that put on the new tyres. I tried last weekend to remove but couldnt with the standard wheel wrench with a small bar on the end. They are just tight rather than siezed as they were only fitted about 2 months ago.
This weekend I plan to replace the rear brake pads so need to remove these wheels.
I plan to use a long scaffold type bar on the end of the wrench.
However, I'm worried about the bolts potentially snapping - any tips to do prior to attempting to remove that will reduce the chance of this?
The bolts are 1 year old FEBI steel wheel bolts (not the alloy ones) as my winter tyres are currently on the car on steelies.
thanks!
Derek
thanks!
Derek
