After bending my neck for 5 minutes looking at your wiring diagram, one obvious problem is the wiring to the " Power" ISO Connector, which is on the far left of your dash cut out. Generally, ( not on all cars so check with a multimeter ! ) the large diameter brown wire is the earth wire, and above this is a red power wire, which seems missing on your connector. This would coincide with pins A7 and A8.
Just a caveat but some cars need the red and yellow wires swapped over ( Power and Switched Power ) but you can check this easily with a multimeter and ignition on and off. Probably a wise move to check this to begin with so you dont get confused.
I am unable to see where the other wires in your connector go but sort these out first before you worry about the speakers connector. A pen and paper are handy for making notes.
If you need to swap pins in connector around, slide a very thin watchmakers type screwdriver into the connection pin and bend the locking tab and it will come out. Just push the pin back in and the locking tab will lock it again
From looking at the Speaker wires ISO plug everything looks ok there.
Steve
