I need all 4 door seals for my 1999 C43 and the stealership quoted me €220 each, has anyone here had experience with aftermarket seals? Thanks in advance
Hi
Can you even buy aftermarket door seals?
I would look for second hand ones on ebay, there is nothing special about the door seals on a C43, so any model 202 will do for it.
It works a treat, was very cheap, but doesn’t cover the trim the same as oe. Not a problem in a £500 car. And is watertight. You might want to research a little for your application.
