steveskeggy
- Jul 4, 2011
- S55 AMG
OK, my car is a 2003 S55 AMG W220.
It does not have start/stop, so it has just the one battery in the boot.
It eats batteries at differing rates, the drain is OK, it has just always done it.
I am used to it eating a battery every 18 months, but every now and again, I will get one that only lasts six months.
I dont use the car every day, and I think this may have something to do with it.
But I dont need advice on what may be causing any drain or how long a battery should last, I know I would be as well sorting out the cause first, blah blah.
What I want to know is, On the W220 site, it says that Mercedes Benz recommend an AGM for the W220.
However, I keep coming up on conflicting statements, saying that to use an AGM, the car would have to have extra equipment (Dont know what) and it would have to go on STAR to tell it that the Battery is AGM.
I also read that if an AGM battery goes under 10v it is basically stuffed, not much use in my circumstances.
If it is a faff around, I will stick with Lead/Acid, but as AGM batteries are supposed to last longer, it may be better if I can.
