gavatron06
Ahaaaa help white smoke! Have a very smokey E220 85K, I read in some of the forums de-gunking the ERG & its manifold can clear this. Removed the cast piece that houses the ERG valve and gave it a good clean with de-greaser. dried with a hair dryer and left to a few hours before refitting.
Usual removing bolts from all over the place, but there were four bolts in particular into the engine block that were a real pain. Particularly the lower bolts, was under the car nose to gear box, reaching around one hand only fit, trying to tighten "posi" drive (Not sure if that the proper name like a square alen key but with tapering multiple sides), who fits this kind of bot its useless!!
Managed to get the top bolts in full & lower bolts in half, before the "posi" started to slip. Time wasnt on our side and @3:30AM last night, decided to take the car for a spin to see if would hold out until today when I could get proper hex bolts. Took off down the road for about 1/2 a mile with a plum of white smoke behind me!
My theory is the water circulation for the heating is escaping into the exhaust and evaporating.
Have I caused damage driving?
There wasn't a gasket between this cast piece and the engine block, should there be? or any type of sealant?
Attached: Photo of the view from underneath.
