I have a 2004 c180 coupe. The problem I have is the air con will only blow hot (28oC) regardless. It has the non digital dual zone via 2 temp dials.
I took it to a garage and the re gassed it. They said the system was empty, they checked it for leaks and said there were none. But this didn't stop the problem.
I have tried the reset by holding the defrost and re circulate buttons, same result.
I have done the paper test on the vent on the air con panel and the sensor fan is working. Is there 2 sensors in the cabin?
If there are 2, is the other in the roof light panel?
Please help, sweaty and Merc's just don't go
