How old is the car, how often do you use the aircon, have you ever had the aircon serviced ? etc etc etc .Checked out today and seems compressor has seized up,just when the hot weather hits us eh.......Great !!
The reason I ask is because the air con didn't get very cold on my C55 AMG so I took it for a service.
I was surprised to learn that on my engine the compressor runs all of the time unlike other cars I have had that have a clutch mechanism to 'disconnect' the drive belt from the pump when not in use. Instead the pumped gas/fluid is regulated through a valve on demand.
The upshot of this is that even if you never use your aircon a lack of fluid in the system will kill the compressor.
I am sure someone on here knows exactly how it works. Your car might have the same system.
