Air-con not coming through centre vents
The coloured tubs are going into a “Black” valve “block” and then there is the engine block, that’s where the exhaust comes out of.
Dec
Oh! I've just found out that when the EC button is pressed, it takes about 10s or so for air to come out from the centre vents! With EC switched off, there's no air. Do you know why air is pushed out from the centre only in EC mode?
EC is economy, it turns off the aircon and Red light illuminates to show aircon is off.
Maybe a fault in the heater control unit?
Do you have the user manual for that car?
Is there a good healthy blow from the center vent on setting 5?
Dec
Would seem some electronics is allowing the flap to open to allow air through the centre when the aircon is off. All very odd.
The manual is for an electronic version so not much use.
Dec
