paulmb
has anyone got a wiring diagram of the complete air con system for a c200 sport 1999?
my air con comes on and off intermitently......
the clutch kicked in every day for the last 10 days and yesterday, it stopped working........prior to the 10 days, it did'nt work for 3 days........
i have a feeling that the 12v supply to the clutch has a break in it somewhere and i want to bypass the original supply wire and feed a new 12v straight to the clutch................i want to make sure that i don't miss out any other important connections on the way.......
i don't know when the pollen filter was last changed....would this have anything to do with it......is it cutting it out as a safety feature?
the coolant temp sensor has been changed and it has been regassed with dye in it..........checked with uv glasses, no leak anywhere...........got to be an electrical fault....
