Air con rad CLK230
rsv clk
CLK 320
I have gassed the system after finding a hole in the pipe to the compressor just to check it but there appears to be a hissing sound :eek:( a leak ) from the condensor unit at the front.
This is a CLK230 Kompressor2002 does anyone here know if it is an easy job or if any rad fits off anything else.it is the one in the lower section of the front rad I assume it has a stone hole in it.
I managed to repair the pixels on the dash today which on reflection I should have bought the type you have to heat bond but did it anyway but a bit fiddly :Dand put a new drivers glass in which was a mistake.:wallbash:
I thought it was a grey tint window but when I removed it I found out it was a very good film fitted to just that window but put the one in I had anyway.
